Region de mascara en vista de plano
artcas
artcas
Hola de nuevo,
Mi duda es la siguiente:
Tarabajando en la vista de plano de Revit 2019, quisiera montar un plano con alguna "trama" hecha insitu solo para ese plano.
En Anotar >Detalle, no se pone activo la opción de Región.
¿Cómo puedo hacer una Región o Trama cuando estoy en vista de plano?
Muchas gracias de antemano.
Saludos
Alan.johnson1970
Are you sure you are in a plan view?
If you are in a top view of the 3D view it wont work.
AJ.
Sounds like you are in a 3D view.  Are you?
artcas
Thankyou @barthbradley and @Alan.johnson1970.
It has been a translation error from Spanish.
I mean when you are assembling the presentation sheets mode.
Look attached.
Thnx
Ah! I see!  Do you want to see something wicked cool?  Then go to this link:
https://www.youtube.com/watch?v=RjYzdHNMQKw
artcas
@barthbradley my hero!
I have been looking for this for a long time. You solved a big problem I had.
Thank you very much!
See you in the next!
Your welcome, @artcas.
How about marking it as the Accepted Solution?
Thanks!
Cheers!
