Reflected Ceiling Plans
5 REPLIES 5
1199 Views, 5 Replies
Hi Everyone
I am setting up sheets and views for our ceiling plans. I need to show the ceiling plan but then also include the roof above and then the balcony outline of that level (I will include an image to try help explain what I want to do). The roof above needs to be a black hidden line, just to show the out line. I have done this by using the view range and setting the "Top" to level above and then the "View Depth: Level" to the level above too. I have put the underlay on as the "Associated Level" however no matter what I do with the Graphic Overrides it stays grey. We need it to be a simple black line. Is there another way to do this? I have considered drawing a 2D line on the outline of the balcony and then removing the underlay. However there are multiple views that this will have to be done to.
Regards
Lauren
5 REPLIES 5
josemukalel
Jose George
Architectural BIM/CAD Technician
josemukalel@gmail.com
+64 22513 0828
A KUDO is always welcomed; However, WHEN the above answer helps and/or clarifies your query; kindly mark it with ACCEPT AS SOLUTION
josemukalel
Jose George
+64 22513 0828
in reply to: josemukalel
I used the linework tool, it works on the slab edge, but this does not work on the balcony railing.
josemukalel
Its working with me
Jose George
+64 22513 0828
I've tried changing the railings to a square edge. I'll try work something out with them. Thanks for the linework idea, I thought there might have been a more efficient way to do it, to apply to the whole view or multiple views.
Forma Design Contest
