Reference Planes lose Line Pattern
jakub_mendel
Message 1 of 12
jakub_mendel
Hi everyone.
For some time, in families, my Reference Planes lose Line Pattern from default to solid. Saving a family with new settings in Object Style does not help.
What could be the reason ?
I am using RVT LT
Replies (11)
Message 2 of 12
Did you change the object style of the pattern in the family editing mode or in the project?
Message 3 of 12
martijn_pater
Maybe try creating a new subcategory for the families reference planes... maybe they are overwritten somewhere in vg(/filter?). Tbh I'm not completely sure if I understood the question though.^^ Hope it helps anyway.
Message 4 of 12
Are you opening the Family from the Project via Edit Family, or via File=>Open=>Family?
Message 5 of 12
jakub_mendel
I creat a new style in the object style of the pattern in the family. It works at 2016 < 2019 version. i have this problem at updat version 2020.
Message 6 of 12
jakub_mendel
Does it matter ?
Right now I testing it at my private computer.. I did this sam like always, and no problem. So..?
I don't have any idea.
Message 7 of 12
It does not matter. Reference planes do not print.
Message 8 of 12
@ToanDN wrote:
It does not matter.
What are we talking about? Ref. Planes in family are different from what was last saved; right?
...yep; just re-read OP's first post. "my Reference Planes lose Line Pattern from default to solid."
Try this: Change Ref. Planes in Project to Solid. Group a family in the Project.  For example, group the OOTB Desk.  Now, TAB-Select Desk and open it via Edit Family. Ref. Planes are solid in Family; right?  Close family and reopen Desk via File =>Open=>Family.  Ref. Planes are dashed; right?
Message 9 of 12
jakub_mendel
it's not a solution 😉
Working with family if U have RP at solid line style is frustrating.
Message 10 of 12
I said that because you asked "does it matter?". Maybe I misunderstood your question. Can you share the family?
Message 11 of 12
jakub_mendel
It's weird but true.
Tomorrow I will check what line style I have at the project.
I'll tell you how it works.
Thanks.
Message 12 of 12
jakub_mendel
Yes indeed, in the project, in the object styles for RP I had Line Style solid. Changing the style to dashed solved the problem.
Thanks for the help.
