Create a custom paper size in Revit
Message 1 of 8
I need to create a custom paper size to print from in Revit.
Replies (7)
Message 2 of 8
martijn_pater
What do you mean, a new titleblock or pdf/printer settings?
Message 3 of 8
Not a new titleblock. I need to create a page size that is 16" wide x 12" and send it to a particular printer that is installed on my computer. I have a list of page size options but none of them are what I need so I need to make a new one. The printer I am sending to is a laser cutter.
Message 4 of 8
martijn_pater
I've never used laser printing straight from Revit. It's probably printer settings, so not within Revit... I think. I am curious how you do it though, so let me know how when you get it working. 🙂
Message 5 of 8
I did change the printing settings in the laser printer driver but every time I use that paper size in Revit it says "incompatible paper size". Is there anyway to add a paper size in revit without printing to a pdf?
Message 6 of 8
martijn_pater
As far as I know paper sizes are just printer settings on your system. When you've added a paper size you might have to restart Revit though.
Message 7 of 8
Try Revit to PDF to Laser
Message 8 of 8
No issues with creating a custom parer size for a Printer and print to that size from Revit.  Show your Revit print settings and the series of dialog leading to the errors.
