Reduce dimension circle with work plan
if I reduce work plan the circle the corrisponde to the level remain in the same dimension.
Can I reduce to the same or delete eventuality?
Thank's
FGPerraudin
hi @Anonymous,
Try changing the scale of your view.
The circle is an annotation object with fixed dimensions according to your "paper" space.
If your element is very small, work with 1:5 or 1:1 scales.
Once the family is loaded into a project, these annotations are not visible anymore, so do not bother too much.
However, if you want to hide them, follow the steps:
1. select the view in the navigator
2. open V/G overrides
3. in annotation tab, untick levels.
Cheers,
François
Francois-Gabriel Perraudin
BIM management and coaching
