Rebar cross section view
I'm a little bit confused wth Revits cross section views. Sometimes rebar is shown correctly and sometimes it is like this (missing part of stirrups):
I've set host element transparency to "100" and made a perfect orthogonal cross section view!?
What else can I do? It's really annoying.
Regards!
-FDC-
I would say this is a view depth issue (far clip offset).
Can you post your drawing or only this part of it?
Thanks for your reply!
Here's a picture with depth:
-FDC-
Posting your file would be better to check it.
Did you try setting deatil level to fine ?
What version of Revit are you using ?
I'll try to upload my file later!...It's a little bit big though....
Detail level is set to fine!
I'm using Revit 2018.2!
