Realistic Visual Style Shadow only showing on half of Floor Plan
troy_troy
Message 1 of 21
troy_troy
I have a floor plan and am using Realistic Visual Style. For some reason the shadow is only showing on the lower right half of the plan. If I choose Top View from 3D Views, it works properly.
Could someone please confirm whether this is a bug or suggest a way to fix? Thanks.
Replies (20)
Message 21 of 21
troy_troy
I ended up layering it.
'Textures' to provide consistent transparency and allow model lines under surfaces.
'Realistic' to cast shadows under transparent objects. Phase Overrides to remove textures. Colour Correction for greyscale and brightness.
Blend in Photoshop
