re-creating excel table in schedules
drew3070
drew3070
I'm incredibly new to Revit schedules. I am trying to recreate this excel table in Revit so it will automatically fill out most/if not all of it. It needs to be able to find a family figure out how many there are, what the lengths are and calculate the lineal footage as well as what page it is on. I'm not sure how much of this is possible but I think some of it is. But I know that it will all involve parameters which I can't seem to wrap my brain around.
This is what the current file looks like. I should mention that this will be used with wood panels on wall/ceilings and well as wood planks.
jay_colc
You could achieve this is many ways if panels are to be used for multiple purposes you could sort them by room and levels and hide these parameters as they are for sorting only.
You should be able to pull the dimensional and weight parameters automatically and create Type Marks for the Panel references.
As regards per sheet you would need 2023 or 2024 as I recall there being an option in the Schedule Filter to do this per sheet.
https://youtu.be/U2dS31VsvQs?si=QNHl6Ihf9204mgET
Jay Colcombe
Autodesk Certified Instructor
syman2000
Depends what you want to achieve. Do you want to build dummy schedule or use Revit object to generate the schedule? I would first start with generate Revit object to generate the schedule. Check the video.
https://www.youtube.com/watch?v=M7q9Dt5CVYo&list=PLeGOnDeTX2hSjytLA93icH8wuDlj7SH1R&ab_channel=CADLe...
jay_colc
Wood Panels!
Jay Colcombe
