How do you create a multi comment tag?
djn9SY84
djn9SY84
Hey guys,
i want to create a tag where i can add multiple comments and have more control over the spacing of the text.
i found a document online describing exactly what i want, image below. does anyone know how to do this?
jay_colcombe
That’s  really is not a multiple comment tag but more of a tag with multiple options for positioning of a single comment parameter.
If you want multiple comments you need to add additional Parameters into the family.
And then space and set them out as desired
Alternatively you can utilise unused parameters
Jay Colcombe
Autodesk Certified Instructor
syman2000
It is quite simple if you follow the steps. If you want to learn, just look at the sample and reverse engineer it to fit your need.
