Re: CEILING HEIGHT ON FLOOR PLAN
I am trying to get a tag telling the ceiling height on my floor plans using spot elevations - option 1.
I use underlay, looking up (base level=floor plan in question). I tag my ceilings with spot elevation. But as soon as I turn the underlay back to "None", all spot elevations hide. And if I turn on underlay they show up again. What am I doing wrong?
Thanks for advice,
//Anna
Nothing. Your annotating a view. If it ain't in the view, then there's no need to call it out in the view.
Viveka_CD
Hi Anna,
What are you view range settings?
bimscape
You are not doing anthing wrong- that is how Underlays and Tags are supposed to work.
Underlays are a temporary, working tool- allowing you to temporarily see another level in order to help you develop your model / detail in a particular plan view
Tags have to be associated with the element they are pulling their data from.
So putting the two together:-
-You turned on the temporary visibility of your ceilings (as an underlay)- so that you can see them
-Because you could see them, you could tag them
-You turned off the underlay- so they ceilings dissapeared. Can't have the tags without the elements- hence the tags went
Any reason why you can't just tag the ceilings in a Reflected Ceiling Plan where (obviuosly) the ceiling elements are visible?
Kind regards,
Ian
Author of The Complete Beginners' Guide to Autodesk Revit Architecture (free online course)
Corsten.Au
You cannot tag anything which is not visible in the view..
( underlays are temporary, so you cannot use elements in underlay to tag spot elevation )
1. Only way to get spot elevation of ceiling would be Ceiling (RCP ) plans..
2. workaround would be : you can have a Room tag with custom " Ceiling Level " parameter and enter those
parameters in " Rooms " to show up in custom tag..
Cheers!
Corsten
Building Designer
