Re: Can't install the Revit add-in
m-vilches
Observer Observer
m-vilches
Observer
Observer
I'm running into that same issue but the link in this thread has expired or is no longer valid. Can anyone help?
-Mike
buzz.ambroseno
Hi Mike,
Are you running into the error with the same file path (aside from local user) as the original poster? Any additional information (screenshot, etc) will be helpful.
Best,
Buzz
m-vilches
Observer
Observer
I downloaded this file to install the BIM Add-in and I get the same error popup that the other user received. I'm on a Windows 10 system and I'm installing as the administrator. I also tried re downloading the installer. I've used both the MSI and exe on two different systems and I get the same error.
https://s3.amazonaws.com/autodesk-buildingops-utility/AutodeskBIM360OpsAdd-in-1.0.10-x64.zip <>
