Adobe PDF Printing Issue
I am having trouble Plotting the PDF files from REVIT 2019 full version with ADOBE PDF.
1. I tried plotting multiple sheets together and it does plotted first sheet but after that it freezes unit I end task from Task Manager.
2. I tried plotting one by one sheets but again it is potting first sheet perfect and freezes for the second one.
3. I looked for several solutions online and did purge my file, deleted all of the %temp% files from my computer, had low resolution for plotting but stills it's same issue for me.
It will be really stress relieving if some one can guide me. It is very frustrating when you have to submit the drawing set to client and it takes more than 1.5 hr to just plot 15 sheets.
Viveka_CD
@Anonymous
Can you try with another PDF printer?
(Alternative option) Use a different PDF writer:​
If you have multiple monitors, please disconnect and try again.
Viveka,
I figured out the problem.
Under Adobe PDF document properties/ Prompt for adobe PDF filename, I set the path to folder I wanted to save and it worked.
Thank you!
Have a look in the Revit App Store for the apps that have extra features in creation of documents (PDF, DWF, DWG). There are a few that do advanced filenames, auto-size, and auto-rotation, etc. They are optimized for printing, so they make the job really quick and stress free. Most of these apps are very economical.
My favorite is:
https://apps.autodesk.com/RVT/en/Detail/Index?id=6842090281765127625&appLang=en&os=Win64
