check the wall joins...they may be off...
Dzan Ta, AEE, ASM, ACI.
Win 11 Pro/DELL XPS 15 9510/i9 3.2GHz/32GB RAM/Nvidia RTX 3050Ti/1TB PCIe SSD/4K 15.4" Non-Touch Display
The footings automatically join and respond to the walls--so, try editing the wall joins and see if the footings clean up.
For instance, try using disallow join on one or more of the walls, and then drag the ends manually, and see if the footings join differently.
You can also drag the ends (blue dot) of the footings.
Worst case, you could try using an in-place Void family to cut the footings.
disallow the the wall join of the wall that's intersecting the angled transition (the one that's vertical in the top picture).
Thank you!
I managed to fix one by moving the footings blue dot, and the second one by editing wall joins.
