schedule panels
2 ANTWORTEN 2
GELÖST
Nachricht 1 von 3
htews
526 Aufrufe, 2 Antworten
schedule panels
is there a way to create a schedule that will list each curtain wall and the systems panels (vision glazing and spandrel glazing) and their area?
2 ANTWORTEN 2
Nachricht 2 von 3
dzanta
als Antwort auf: htews
yes
Choose Schedule command
Choose Curtain Panel Category
Pick the columns of fields you want to schedule out
Dzan Ta, AEE, ASM, ACI.
Autodesk Community | Twitter | YouTube | Facebook | LinkedIn |
Win 11 Pro/DELL XPS 15 9510/i9 3.2GHz/32GB RAM/Nvidia RTX 3050Ti/1TB PCIe SSD/4K 15.4" Non-Touch Display
Nachricht 3 von 3
A curtain panel schedule will give you the panel parameters but not the curtain wall where they belong.  You can select all panels of a curtain wall in the project and give them a common identity value (for instance the same Mark value as the host Curtain Wall Mark).  Then, you can group them per that parameter in the schedule.
