Ray Trace Issue
Ray Trace Issue
Message 1 of 8
Ray Trace Issue
Hi Folks,
I am having an issue with a model I am working on. When I set it to a realistic visual style it appears nearly black so I adjusted the graphic display options to fix the issue. However, when I set the visual style to ray trace the model appears black(see attached jpg). At first I thought it was the light fixtures so I deleted them out but this was not the problem. Can anybody offer some advice? Thanks in advance.
Eamon
Replies (7)
Message 2 of 8
Hard to say what's going on. We can start by looking at your rendering settings. Post a screenshot showing those.
Message 3 of 8
Thanks for the reply. See attached.
Message 4 of 8
MostafaElashmawy
Would you please show the sun settings.
Mostafa Elashmawy
Message 5 of 8
It's because your view is looking up at the bottom of the building and towards the sky.  Basically you're below the ground  and the below the shadowing.
Message 6 of 8
...and it's late in the evening, close to sunset.  It's probably an accurate rendering.  Smiley Wink
...I'm kidding of course. Here's what I get when I Render the OOTB "rac_basic_sample_project.rvt" with the same sun settings you have selected (<in-session, still>).  Yes -- and looking down at the building:
Message 7 of 8
Corsten.Au
While rendering, in Lighting Scheme, try " Exterior Sun only"
Corsten
Building Designer
Message 8 of 8
@Corsten.Au: I think all he need to do is change the time of day for <In-Session, Still>.  Here's the same Ray Trace as I did above, but the time of day on this one is 11AM.  I think the OP's is done at dusk or dawn.
