Rated wall pattern
Rated wall pattern
yes_and_no
Message 1 of 15
Rated wall pattern
yes_and_no
We normally use graphic line over wall center for this purpose, but the line won't move as the wall moves (locking it seems more work unnecessary).
I use pyRevit to make filled region pattern ok on plan, same size. But ít won't apply to graphic override. Perhaps i missed steps somewhere.
Anyone ?
Replies (14)
Message 2 of 15
Coarse scale pattern for coarse and cut pattern for medium/fine.
Message 3 of 15
Mike.FORM
We use a key schedule to set our fire ratings for individual walls.
Then for our Fire Separation plans and building sections we have a filter that reads the Fire Rating Designation Value and applies a specific cut pattern override.
Message 4 of 15
yes_and_no
Your method involve doubling wall materials and wall type families which we
try to avoid (being R17, under 2GB file size).
I was talking about graphics override in VG or perhaps filters.
Message 5 of 15
TripleM-Dev.net
Hi @yes_and_no ,
If the Rated value is a parameter value in the wall, then use viewfilters to override the appearance.
"I use pyRevit to make filled region pattern ok on plan, same size. But ít won't apply to graphic override"
What doesn't apply to graphics override?
Message 6 of 15
A non fire rated wall assembly and a fire rated wall assembly deserve to be in different wall types.  That is why the OOTB Fire Rating parameter for walls category is a type, not an  instance parameter.  Adding a few more steel stud materials for different rating shouldn't increase the file size by any amount that should concern you. Think about a few hundred KB added to GB model.  Big deals?
Using filters work graphically but filters come with their own can of worms.  They are view / view template based instead of project based, so deploy them and modify them in the long run take more time and repetitive work.  But yeah you will save a few hundred KBs.
Message 7 of 15
yes_and_no
Hi Toan. You are correct (as always).
There are myths about Revit that most people used to. "Using
graphic/symbolic lines are "not Rv way", "messing up OTB materials causes
Rv to crash"...to name a few.
While rated walls only been shown in one sheet (our STD), we incline to use
graphic Lines(1) or Graphic Override(2).
Given choice (2), do you have any suggestions/solution ?
As in (2) the wall currently can take solid shaded red color, I wonder why
can't ít take a patterned dash.
Message 8 of 15
Mike.FORM
These are the patterns we use for our ratings.
;%VERSION=3.0
;%UNITS=MM
*0.5 HR FRR, 0.5 HR FRR
;%TYPE=DRAFTING
0,    0,0,    0,0.1,    0.8,-1.2
*0.75 HR FRR, 0.75 HR FRR
;%TYPE=DRAFTING
0,   0,0,   0,0.1,   5,-1.5,0.8,-1.5
*1 HR FRR, 1 HR FRR;
%TYPE=DRAFTING
0,   0,0,   0,0.1,   5,-1.5,0.8,-1.5,0.8,-1.5
*1.5 HR FRR, 1.5 HR FRR
;%TYPE=DRAFTING
0,   0,0,   0,0.1,   5,-1.5,0.8,-1.5,0.8,-1.5,0.8,-1.5
*2 HR FRR, 2 HR FRR
;%TYPE=DRAFTING
0,   0,0,   0,0.1,   5,-1.5,0.8,-1.5,0.8,-1.5,0.8,-1.5,0.8,-1.5
Message 9 of 15
TripleM-Dev.net
Hi @yes_and_no,
"Using graphic/symbolic lines are "not Rv way" ... Don't know who says that, but using graphics overrides IS a 'Rv way'
Maybe in terms of BIM using detail lines and not giving the 3D elements that data or keeping that in sync, Yes I can relate to that.
"As in (2) the wall currently can take solid shaded red color, I wonder why can't ít take a patterned dash."
So with a Graphics override with color + 'dashed' pattern the wall doesn't get the pattern?
- Is Cut Pattern overridden? + is wall cut (I assume floorplan)
- Maybe the dashed pattern is to dense, check other viewscales
- View set to Detail level Coarse, maybe it overrides with the Wall's Coarse pattern? (Not sure if a ViewFilter would override it) anyway, set the view to Medium or fine. (or else just the wall category in the view/template)
"messing up OTB materials causes Rv to crash"...uhm never had a issue with this.
- Michel
Message 10 of 15
To make a fire tape pattern work with filter, edit the pattern and make sure it is set to orient with element, not view.
Message 11 of 15
yes_and_no
Per yr advice I successfully made the rated pattern appears in plan, including in PDF print.
One step up, how do I do this as a filter, without making separate wall type ?
Someone suggests doing a wall schedule with tags, that s counter productive, IMHO.
Message 12 of 15
Mike.FORM
We use a key plan so that we get a drop down parameter in our wall properties that we can use to set several parameters. We then check our Fire Rating Designation parameter with several filters to set the correct cut pattern to walls, floors, ceiling and roofs. The Fire Rating Designation is a letter value and we also show this in our standard wall tags.
Message 13 of 15
TripleM-Dev.net
Hi @yes_and_no,
If you don't want to create Type per Rating, use a instance parameter.
I see @Mike.FORM post uses a key schedule to populate the instance parameters, if the rating includes more than one value use that as solution.
Message 14 of 15
azad.Nanva
why are you not using the filter and pattern or line pattern ?
or use the line as attached details group with lock to the walls:
Message 15 of 15
clement.dirawu
Man this is quite useful. You saved me a lot i had a deadline and needed this so bad. Much appreciated
