Railing Question: can you use "distance from previous" in the Baluster placement type properties as a maximum baluster placement.
I would like to use the "Spread Pattern To Fit" justification rule to automatically calculate baluster spacing instead of having to calculate spacings by hand. In the work I do, the strength of the balusters limit the baluster spacing to 7'-0". As such I would like the "Spread Pattern To Fit" justification to consider the "dist. from previous" property to be a maximum limit instead of a goal.
Is this possible? Thank you for your time.
