Length of a curve between adaptive points
mtanyer
mtanyer
Dear all,
I have 3 adaptive points and a reference line (curve) between these.
I would like to measure the length of this curve and map to a parameter.
In the picture, although the perpendicular distance is 20 meters, the actual length of the curve is 20.3564 meters. I would like to use the actual length.
How can I do this?
Thank you.
RDAOU
@mtanyer
Within the family environment, it is only possible by defining the curve length using a trigonometric equation and using a shared parameter. Unless you are modeling it in-place (in the model)
If the above is not possible then another solution would be to use dynamo after you place it in the model to get curve length and write to a parameter in the family
Try this approach:
https://haynearchitects.com/tips-tricks-spline-length-in-revit/
Sample 2024 family attached.
RDAOU
@ToanDN
I do not have 2024 and I am curious..does that not require the splines to be in an in-place mass? I might be mistaken but I do not think the min & max length of the divided path segments carry over with the family to the project environment
@RDAOU you are right.  The family does not work in projects.
Without Dynamo, you could create a form with known profile (1" x 1" for instance) and the sweep spline.  Then create a generic models schedule or a material take off schedule in the project, create a calculated value parameter to get the path length = Volume / profile area.
mtanyer
Dear all,
I try to implement your suggestions. Let me summarize what I have:
I have a family that is based on 2 adaptive points. I try to insert this family onto a curve on the project side. I know the points on the curve.
However, the distance between the points (segment length) are slightly different from the chord length.
As you have suggested, I have converted my reference line to a "divided path" and the features are as follows. The "distance" parameter is mapped to the "SegmentLength" parameter.
Unfortunately, the family cannot be created properly on the project side. How do I measure the actual length between 2 adaptive points?
