Railing - managing length and joining with terminations
maciej.rudecki
Message 1 of 13
maciej.rudecki
is there a possibility to control the way the railing joins with the terminations? As you can see on the picture below, it doesn't connect automatically and I cannot find any setting that controls it. (The railing is sloped since it is hosted to stairs.)
Secondly, I'd like to shorten the lower part of the railing (T profile) a bit but the "Length" parameter is greyed out - maybe there's some way to unlock it?
The upper part of the whole railing consists of: the "handrail" with "terminations" (round profile) and the "top rail" (T profile)
Thanks in advance!
Replies (12)
Message 2 of 13
RDAOU
@maciej.rudecki
For the termination and the way it connects to the rail, you need to edit the termination family and model the transition/connection therein...you can find them in the project browser >> families >> under category Railing
For the length ...Edit the sketch of the rail first to shorten a notch finish sketch then  tab select the top Rail >> edit the Profile >>> extend it slightly
Message 3 of 13
You cannot shorten a top rail without an extension.  In other words, the top rail (and handrail) sketch cannot be shorter then the railing sketch.
If the railing is not on a slope, you can draw the railing sketch the same length as the T length, offset the start and end post outward, and add extensions to the round handrail to compensate the length difference.
For simplicity, you can create the T as a separate railing type, and sketch it shorter in the same place as the main railing.  That would work for both flat and slope conditions.
Thanks in advance!
Message 4 of 13
RDAOU
Extended without the termination by editing path as mentioned above ... Alternatively you reset the path and extend using a custom termination family
Message 5 of 13
Not clear what you want, but I'm wondering if you can get there with an "Extension Style" and "Length" (under the Type Properties for the Top Rail).
Message 6 of 13
maciej.rudecki
I cannot find the "transition/connection" option in the termination family in edit mode. Could you please explain to me where this option is located?
Message 7 of 13
RDAOU
@maciej.rudecki
It is not an option ... you have to use a family template or edit an existing one and model it therein...ie: you create a custom termination family using extrusions, sweeps, blends...etc that follows the slope/angle of the rail from one end and extends further in which ever direction you wish or shape you desire
If it is a simple thing similar to the image I posted above, then you do not need a termination...you can achieve that by editing the Top Rail path
How about you sketch how you would like the end product look like?
Message 8 of 13
maciej.rudecki
Thank you for the response.
According to what you wrote, I assume there is no possibility of creating the railing the way I want it to be using just one railing family.
I will try then to model it using separate families or maybe create a new railing family, but I need it to be adaptive and usable as the built-in one, so it won't be easy.
After all, the point is to schedule those railings with all the needed dimensions and quantities (railing length, height, number of ballusters etc.) so I think the easiest way is to create two railings and assign the same parameter value in order to schedule them as one.
Below you can see a photograph of the railing - maybe you'll come to some other solution.
Thx
Message 9 of 13
maciej.rudecki
Ok, I created the termination just as you described it.
I can see that it connects well with the horizontally aligned handrail but doesn't work with the sloped one.
The railing itself is very simple, I didn't expect it to be so problematic to model it.
You can find the photo of the railing in the post above.
Cheers
Message 10 of 13
RDAOU
@maciej.rudecki
You need to edit the Top Rail Path and give it a nudge forward (you can reduce the Termination thickness to deduct the added height
Message 11 of 13
maciej.rudecki
Wow, I didn't know about this trick. Thank you very much!
Now I am proceeding to counting balusters... I think this will be the case for another topic :pp
Again, thank you!
Message 12 of 13
mark.williams53421
Community Visitor
Community Visitor
I have recently stumbled on these sites that provide Affordable and Professional Railings and Custom Iron Work. The guides are super easy to follow and I actually enjoyed their services. You can also check the website yourself: https://www.abbcorailing.comhttps:
Message 13 of 13
mar_zan
When I tried this it still cuts the custom extension perpendicular to the ground. I'm stumped what is causing this.
