Railing Issues
I have been trying to get my stairs to work for over a week now and finally figured out the stair run and can't get the railing to cooperate now. I am sketching my own path instead of the "place on host" method because placing on host is the most non user friendly method. It's horrible. Autodesk really needs to let the user delete segments of railing for this method without getting the "line must be continuous" error message. It enrages me.
I am trying to to run my path up multiple levels and it works fine until I have to cross an existing path to progress but I get that "line must be continuous" message and I can't go any further. However, if you use the place on host it has no problem overlapping a path. So frustrating that you can't do the same when creating your own path. I have a feeling that I must make each stair run a separate entity in order for the railing to attach to it. Make several different hosts if you will. Anyway, that is my question, how can create a multi-level custom path for my railing?
My file:
