Right. I tried the "accepted" solution to no avail. But I think this thread is more about "seeing" the railing on a floor above or actually at the ceiling.
My situation is a regular rail (mezzanine) and the railing is at floor level and 42"high. for my RCP view (lighting) I want to show the railing to show where the mezzanine ends.
Using underlay shows everything from the level below, so that doesn't work for me. I tried a plan region just where the railing is, but can't make it show up.
my only workaround is:
- show underlay (so I see where the wall below is that shows the end of the mezzanine).
- draw an annotation line where the railing is
- un-show the underlay
This is just dumb since it shows a line instead of railing, and if the railing changes, it doesn't change. Good enough for this specific case, not good enough for what we expect from a good software
I found some ideas you may want to vote on:
https://forums.autodesk.com/t5/revit-ideas/allow-railings-to-be-visible-in-a-reflected-ceiling-plan/...
https://forums.autodesk.com/t5/revit-ideas/show-railings-and-more-on-rcp/idi-p/10244241
https://forums.autodesk.com/t5/revit-ideas/option-to-show-stairs-in-true-representation-in-rcp-views...
Revit Version: R2026.4
Hardware: i9 14900K, 64GB, Nvidia RTX 2000 Ada 16GB
Add-ins: ElumTools; Ripple-HVAC; ElectroBIM; Qbitec
