Hi We have a project consisting of 5 zones on average 5-6 storeys in height so our Master model consists of structure and envelope models for each zone (so 10N° in total) and we have about 18 departments which are split geographically across the building, so we have a file for each department.
We need to export the models to Navisworks as a client pre-requisite but need a relatively efficient and clear workflow.
We don't seem to be able to export the file in 1 go either for the whole building or even by Zone (5 separate models).
Has anyone else had this issue, most of the posts seem to relate to problems within a single file environment.
We have used Navisworks with Microstation/Bentley Architecture and the workflow is quite straight forward, and it is possible to set up a chain of *.nwc and *.nwf files from which we can dynamically export live and up to date *.nwd files. I could be wrong, but the Revit -> Navis workflow seems to be completely manual and piecemeal requiring refreshing the *.nwc files manually every time before exporting a *.nwf which links them in to a *.nwd file for issue.
Any help would be much appreciated as it is quite a concern now that so far down the line we are finding such a BIG issue.!
Thanks in advance
