Railing at multi switchback stair
GREMMELS1
GREMMELS1
I have a stair that switches back 3 times so there are 2 runs at different levels on each side of the stair.  I am having trouble getting the rail to show up on the second run above the original.
Normally I would place a rail on the entire host and start deleting the sketch lines but that is not working for this stair.  When I try and draw a separate rail it is just flat and the slope commands do nothing.  When I then try and rehost to the stair it places the rail back down at the original level.
lucdoucet_msdl
@GREMMELS1
As your stair seems to be comprised of 4 equal runs (or more precisely, two simple switchback stairs) you could create an intermediate level at mid height and use a multi-level stair. This way, the third and fourth runs will reproduce the hand-rails and guard-rails you have modelled for the first and second runs.
Hope this helps,
-luc
P.S. You may want to uncheck the intermediate levels "Building Story" instance parameter and adjust the extents so as to limit where the level shows up.
RDAOU
@GREMMELS1
Use the Split tool and delete the portion which is not required (See GIF Below)
GREMMELS1
Thanks for the tip. Had to us a rail type that had no extensions to split at first and then I could switch it to the desired rail.  I also applied this to the continuous rail in the middle.  I get extra posts at the landing in the continuous rail but at least it joins where the stair is not continuous at certain landings.
