Radial array
Radial array
Radial array
Completely new here....they don't come much greener that I am.  I am trying to create a radial array where the rays are spaced by length on the curve that they will end on.  In the attachment, I need to create an array of the exterior rays that are equally spaced by length of the arc.  I will be using the center, heavier arc to provide the spacing.
Can anyone help me with how to do this?
Thank you,
Vi Eckert
Hello @Anonymous
First create or select the object you want to array
Here is the sample screencast.
Thank you so very much! Is there a way to place them by distance apart in length center to center? The piece that I need to array is a rectangle like you demonstrated with.
Thank you again!
Cheers,
Vi
Hello @Anonymous
Since you are using radial array its better to used angle as reference.
Thank you! I truly appreciate your time. Your video was great.
Cheers,
Vi
Thanks and Good luck
