I have been attempting to be able to control the height of this tall Push Bar on the attached Door family. The Push Bar was created as a Sweep, with an Instance dimension parameter (Height) for the length of the Sweep path added in the path sketch environment (and it flexed successfully). When inserted into the Door family, I attempted to associate the Height parameter was with the Push Bar Height parameter, but received an error message. Any help would be appreciated.
Gelöst! Gehe zur Lösung
Gelöst von Sahay_R. Gehe zur Lösung
Hello
I tried to associate Height parameter with the Push Bar Height parameter and it worked well for me. See attached screencast. What kind of error message did you get?
.....that Revit cannot create the Push Bar, and it will be deleted. Also, the problem is with the tall skinny bar. The others are OK.
I worked around this by cannibalizing a similar (but more successful) pull from another door family that I had created. But it would be nice to know what was wrong.
