Radial Array issue
Radial Array issue
linkboy
Radial Array issue
linkboy
I have created a radial array based on an old post from Alfredo. The only issue is, after change the parameters, the first item can not be pinned to the reference line or related to the reference line. It has to manually adjust the orientation so the group of array centered to the middle line.shot.png alignequal.png
I think you are trying to build a family like the attached RFA. Check it out and see if it helps.
Use a curtain wall with chairs as panels and you never have to be worried about array parameters, constraints.  And it works for any configurations: linear, arc, full circle, partial ellipse, full ellipse... chairs facing in, chairs facing out, chairs with different materials within the row, chairs can be taken out/ swapped to different type within the row...
