"Top reference is bellow Bottom reference for one or more Balusters"
Message 1 of 9
How can I split a railing into three parts? What it says here: https://knowledge.autodesk.com/support/revit-products/troubleshooting/caas/sfdcarticles/sfdcarticles...
I don't know how to fix the warning
Isabel
Replies (8)
Message 2 of 9
PijPiwo
Can you upload your rail with the sketch of what you're trying to achieve?
Message 3 of 9
It happens with all railings I create
Isabel
Message 4 of 9
PijPiwo
I thought you could post rvt file as well …anyway, what the error basically means is that the base and base offset settings for the baluster/post cannot be above top and top offset.
Message 5 of 9
Oh, thank you for specifying!!
Message 6 of 9
andre_adc-dao
I had the same problem. Can you detail your solution?
I dont'have this problem with metric template and I'm using Revit 2017.
Andre
Message 7 of 9
Thank you so much!!
I can resolve my problem.
Message 8 of 9
PWijayasinghe
Community Visitor
Community Visitor
Thanks a lot, man... I was struggling with this for hours.
Message 9 of 9
Mike.FORM
Can you show us the rail element dialogue? You are using "Rail 1" as your top host and have a -100 offset from that element. You also have a 100mm offset above the host so I assume your "Rail 1" is likely not 200mm + above the host which is causing the error. Balusters have a 0 height.
