"Parts" creation error
mtanyer
mtanyer
Dear all,
I have exactly two slabs composed of the following layers: 20 cm RC and 2 cm plaster.
I want to create "parts" from these floors. One of them (small one) creates the parts but the other (big one) does not create parts. The "Create Parts" button is inactive and greyed out.
I have the following error message:
Revit does not allow creating parts from certain elements. Parts will not be created from these elements.
What could be the reason for this?
Thank you.
RDAOU
@mtanyer
Just from that snapshot it is hard to tell. I only difference I see is that you have modified/cut the 4 corners of the slab...if they are both of the same floor type there should be no other reason the following
  1. you have modified the sub elements  of the floor element and in such case the Parts button would be grayed out (and this cannot be it because you can still click it)
  2. you modifying the element with cuts and inserts which Revit Parts do not like. So the only suggestion I can make in this case is to remove those cuts/inserts one by one and see if any of them is causing it
See this article too "Can't make parts out of these Elements [...]" in Revit
handjonathan
Hi @mtanyer
Thanks a lot for posting your question to the forums!   Has the solution suggested by @RDAOU helped with your issue?
We look forward to hearing back from you with more information so we can help you as a community! 
Jonathan Hand
Technical Marketing Manager | Construction
