"Divide" command in Revit?
octavio2
Message 1 of 9
octavio2
Have a line that I want to divide to add ceiling light fixtures.
Is there a "Divide" command in Revit like in AutoCAD?, ...or equal parts command?,  ...or elect between two points?
Thanks in advance.
Replies (8)
Message 2 of 9
The shortcut for object snap between two points is S2.
Message 3 of 9
octavio2
If you have then five lights that you want to put on a previous line that you drew in a RCP, and you want the lights to be equally spaced apart, how do you do that?
Thanks in advance again.
Message 4 of 9
You could build a divided path-based repeater family.
Repeat Adaptive Components | Revit | Autodesk Knowledge Network
Message 5 of 9
constantin.stroescu
I'd use for this a Generic Model Adaptive Family and then in Project Equal function...as shown in my screencast:
Constantin Stroescu
Message 6 of 9
lim.wendy
Hi Octavio,
Thank you for submitting your question in our discussion forums.  It looks like Barth and  Constantin provided you with the steps to  evenly space objects, so for now I am going to mark this as "Solved." This won't prevent other folks from commenting on this question though in the event other ideas come up!
Remember, marking your posts as having an accepted solution really helps out other forum users that have the same issue – so don’t be shy about marking it as a solution! Accepted solutions get viewed more and help more users find the answer to their problems.
If the solution did not work, you can unmark the post as an accepted solution. To cancel an accepted solution, click the ellipsis menu  > Not the Solution.
Do you have any questions about it, let us know if you require further assistance.
Wendy Lim
Data Nerd | Community Advocate | AEC Industry
facebook twitter twitter blogs pm
Join the new online Rail Community
Rails Summit
Message 7 of 9
octavio2
"S2" by itself does not work in Revit 2021 from scratch like that.  I assume it is because it has to be added as a Keyboard Shortcut.   I do not see a command for that particular snap tracking listed in the Snaps (OS) dialog.  What is the full name of that command, that is, if it is listed under the Keyboard Shortcuts dialog so it can be shortcutted there with "S2"?
Message 8 of 9
octavio2
Bart, a "Divide and Repeat.rfa" is included as a family in any of the Revit out of the box family libraries? If so, in which folder it is located?
Message 9 of 9
S2 command is in 2022 and 2023, not previous versions.
You can create the adaptive family yourself, it takes like 1 minute.
