Can you send the Revit model sample you are using?
Select Accept as Solution and Likes are always welcome.
Ralph den Haan, (Lazy) BIM Specialist
Can you try this out? Create a custom Python script node with 2x input and place this script (in CPyton3):
import clr
clr.AddReference('RevitAPI')
from Autodesk.Revit.DB import *
from System.Collections.Generic import *
clr.AddReference("RevitServices")
import RevitServices
from RevitServices.Persistence import DocumentManager
from RevitServices.Transactions import TransactionManager
doc = DocumentManager.Instance.CurrentDBDocument
items1 = UnwrapElement(IN[0])
items2 = UnwrapElement(IN[1])
def CutGeometry(doc, item1, item2):
try:
SolidSolidCutUtils.AddCutBetweenSolids(doc, item1, item2)
return True
except:
try:
InstanceVoidCutUtils.AddInstanceVoidCut(doc, item1, item2)
return True
except:
return False
TransactionManager.Instance.EnsureInTransaction(doc)
if isinstance(IN[0], list):
if isinstance(IN[1], list):
OUT = [CutGeometry(doc, x, y) for x, y in zip(items1, items2)]
else:
OUT = [CutGeometry(doc, x, items2) for x in items1]
else:
OUT = [CutGeometry(doc, items1, x) for x in items2]
else:
OUT = CutGeometry(doc, items1, items2)
TransactionManager.Instance.TransactionTaskDone()
It works for me: (check out the script above and make sure its running CPython3).
