"Cannot extend layer(s) of the highlighted vertically compound wall." error
seutaojiang
Message 1 of 14
seutaojiang
hi I am a new user of revit and I am trying to  unloack brick  layers of the exterior wall (please see the attached image file). But when I open the little padlock and press "ok" button,  Revit gives me an error message:  "Cannot extend layer(s) of the highlighted vertically compound wall."  The walls are not attached to anything. why i get this error meaasge?   How can i extend the brick layer?
Thank you very much in advance!!!
Replies (13)
Message 2 of 14
Select all the walls in the project and Detach All.
Message 3 of 14
seutaojiang
thanks for your reply!!! Do you mean secect all walls, then detach top/base?  i did that and does not work...
Message 4 of 14
seutaojiang
where is the Detach All command/button?
Message 5 of 14
I mean pick a wall and select all similar, then Detach Top/Base=>Detach All.  That's what I do.
....I'll look at your file and report back.
Message 6 of 14
seutaojiang
thanks a lot!!  i did what you described but still cannot make it work....
Message 7 of 14
...works here. Detach All allows me to modify and unlock wall layers.
Message 8 of 14
seutaojiang
thanks a lot!!  I still cannot make this work....please see the attached vedio and is there something wrong in what i am doing?
Message 9 of 14
Interesting.  I just did it.  Selected wall "Exterior - 240 110 brick+40 gap+90 stud", right-clicked and picked Select All Instances=>Visible in View, and then clicked Detach Top/Base =Detach All on Contextual Tab. Afterwards, I modified and unlocked wall layer in Edit Assembly section view no problem.
Message 10 of 14
seutaojiang
did you see my little vedio?
Message 11 of 14
Corsten.Au
Hi
In your file, the outer Brick layer is still LOCKED...
unlock it first the way you showed .
Cheers
Corsten
Building Designer
Message 12 of 14
seutaojiang
hi ganesh :    i cannot unlock it....did you see the vedio i posted?   when i unlock it, it always give me the error message
Message 13 of 14
Now I did. Thank you for the kind comment. The only thing you missed was to "DETACH AL" on the Options Bar after you click on Detach Top/Bottom.
Message 14 of 14
seutaojiang
hi it worked!!!  thank you very much!!!
