Dear Revit Users,
Just a quick question.
Is there any way that I can set wall wrapping for the section of Door Family?
I can only control wrapping for the plan by adding a reference plane, but not for the section.
Yuki
Gelöst! Gehe zur Lösung
Gelöst von barthbradley. Gehe zur Lösung
Did you create right and left wall closure planes in the family? Is closure by host or by family?
@barthbradley thank you for your comment.
Well, I added the reference line like the image and it worked both sides of the door to wrap wall, but not the head of the door. I allowed me to control the depth of wall wrapping in the project which is favorable for me.
As you suggested, I tried to set wall closure to Right and Left References then, now I don't see side patterns either.
What I am missing?
By the way, I also noticed the wall closure setting seems only for the maximum of two references.
Yuki
Yep and Yep. Only two wall closure planes allowed and heads/sills don't wrap. It's a bi-och. But, use can apply material as Paint. That work for you?
Um… I could apply the pattern by paint but the pattern looks odd.
Moreover, if it doesn't show in the section then I think it is no point to use this function apart from expressing in floor plan only.
Anyway, I appreciated that you teach me cans and can'ts and it will be another in the wish list.
Thanks!
Yuki
