"Autodesk.Revit.Exceptions.ArgumentException:" on start-up.
Hi all
Everytime I start up my Revit 2020 I recieve an error message saying:
Fout:Autodesk.Revit.Exceptions.ArgumentException: HelpPath is null or empty.
  at Autodesk.Revit.UI.ContextualHelp..ctor(ContextualHelpType
helptype, String helpPath)
  at RevitDBBImport.StartApp.OnStartup(UIControlledApplication
ContApplication)
I can click OK and continue working without any problems. What is this error-message saying and how do I get rid of this? My OS is Windows 10 and current Revit version is 2020. If I need to provide more information to solve this issue please let me know,
Regards
Richard
L.Maas
Looks like an error with the DB Link add-in. See what happens when you remove that add-in.
Louis
Please mention Revit version, especially when uploading Revit files.
Hoi Louis
I have updatet, repaired and un-installed the add-in. On all occasions I still received the error message when I start up Revit. Are there any other suggestions to resolve this problem?
Regards
Richard
Bronstijn-LA
Hey Richard, on recognizing the error to be Dutch (Fout:) i realized i've had that same error.
I would look into the BouwConnect plugin.... that solved it for us.
Good luck!
Hi Rb
After deleting the BouwConnect-plugin the error message has gone.
Thanks for the tip!
Richard
