WIDTH PARAMETER NOT WORKING PROPERLY
esa.vahtera
esa.vahtera
WIDTH PARAMETER IN NOT WORKING, IF IT CHANGED BY DIFFERENT TYPE. PLEASE CHECK THE VIDEO AND THE ATTACHED FILE.
bin
L.Maas
It is a matter of flexing and testing and some troubleshooting. What I always do is checking the errors and see if that gives me a clue.ALs accepting to remomove he constraint sometimes helps to find the issue.
If it does not then I start with some troubleshooting. Often I will delete parts of the family (e.g some extrusions) and see if/when it starts flexing properly again (undo to return to previous situation). When I find the culprit(s) I start to remodel them or model them in a slightly different way.
In your case it seems the front part of the plinth are causing the issues (see screenshot). After deleting it, it will start to flex properly again (at least based on some quick tests).
So the solution, delete this part and create it again.
Louis
Please mention Revit version, especially when uploading Revit files.
Hi, @esa.vahtera
I don't understand.  There's no question. But, if I was to offer some instruction, I'd tell you not to associate the Extrusion End or  Extrusion Start parameter, and instead align and lock the extrusion's front and back to Ref. Planes that are driven by labeled dimensions.   The reason being that the cabinet is like "growing" outwards from the center, which means BOTH the Extrusion End or  Extrusion Start parameters would need to change -- one in a negative direction.
FWIW:
