quickly apply color to linked revit models
Karol_Piroska
Advisor Advisor
Karol_Piroska
I have a master file with many links and I need several 2D & 3D drawings where models are shaded with a different color.
Does anyone know if there is a way to quickly apply colour in the master file to linked models via filters (or some other way) without having to open each model and add/change parameter(s) and reload all in master file?
thanks
constantin.stroescu
A  quick solution could be by using Worksets:
  • Create different Worksets for every Liked Projects
  • then use Worksharing Display Settings and select desired colours
another more slow method could be a View dependent method by using Annotate >Regions for 2 D and Drafting Views edited into Sheet Views for 3d Perpective views
Constantin Stroescu
