Thanks to all who responded.
I went back to Best Buy and found out that the drive is 5400, they said.
Also I found that the model number is A505-S6025, with an additional number
5, which I originally missed.
Thanks to all again.
"Matt Stachoni" wrote in message
news:6355089@discussion.autodesk.com...
> If I was only using the laptop to demo or "play with" Revit, maybe. But if
> I had
> to actually do work on it, no way. Look for a real Professional model with
> professional specifications.
> For your mom's laptop, the i3 is fine. But for Revit, the i3 is a
> seriously
> crappy processor. It's only a dual-core (not a quad-core) CPU, and doesn't
> have
> the internal efficiencies which makes the Core i7 such a barn burner.
> 4GB isn't sufficient for serious Revit use. Look for one that can have 8GB
> installed. That's the minimum today.
> Windows 7 Pro 64-bit is the only choice in operating systems these days,
> so
> that's a non-issue.
> Make sure the hard drive is 7200 RPM, not 5400 RPM. You can probably get
> by with
> 320GB for typical online data needs and use an external eSATA drive for
> near-line data and backups.
> 16:9 screens are gimmicks to sell "large" screens which really are not
> large at
> all. A 16:9 screen is nice if you watch a lot of movies. Otherwise, you
> are
> losing a lot of vertical pixels which is important in Revit.
> The graphics card is anemic at best.
> And the words "Includes Best Buy Installer Software" just gives me the
> heebie
> jeebies on an AOL scale.
> My minimum Revit laptop specs:
> 15.4" 1920x1200 WUXGA+ screen
> i7 CPU @ 2.0GHz
> 8GB RAM
> Decent dedicated graphics with 1GB RAM.
> DVD/RW
> Built-in SD card reader
> eSATA external connector
> DVI or DisplayPort external connector
> Matt
> matt@stachoni.com
> On Sun, 14 Mar 2010 17:21:57 -0700, Octavio wrote:
>>Best Buy sells the following Laptop, and I would like to ask this
>>Newsgroup
>>if you think that it is enough or good enough to handle Revit 2010 and
>>possibly 2011 (when it is released), and maybe also AutoCAD Architecture
>>2010 or 2011 installed at the same time (only one program will be running
>>at
>>one time, of course). Please advise. Thanks in advance.
>>TOSHIBA LAPTOP MODEL A05-S6025 $799.99
>>Intel Core i-3 330 M Processor Laptop
>>Windows 7
>>Professional 64 Bit
>>4 GB - DDR3 Memory
>>500 GB Hard Drive
>>Battery Up to 5 Hrs, 20 min.
>>16" 16:9 Display
>>NVIDIA GeForce 310M Graphics w/ 512MB Dedicated DDR Memory
>>Dedicated Graphics
>>7.17 LBS
>>Includes Best Buy Software Installer
