- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Sometimes we like to share a 3D model with our clients using the Shared Views function (located under the Collaborate tab) , now we have the problem that walls that are joined and looking perfectly in Revit (native 3D view ) and section are unjoined in the online browser view ...
See some screenshots to clarify our problem, if anyone knows or there are other options to export without loss of joins that would be really helpfull...
How we want it to look (how it does in Revit 3D):
How it looks in section view (also correct how we want to detail it and everything):
A = standard wall construction
B = standard wall construction but with a layer of aerated concrete blocks
C = flat roof
A & C are joined to create the correct connection (the concrete slab wich
lays on the construction wall layer A)
A & B are joined to create a seamless brickwork on the outside , wich works fine in Revit
The problem:
In the online viewer all joins are getting unjoined even the one desbribed above...
(We both tried putting the project on BIM360 and using the standard Collaborate shared views function, both workflows give the same crapy result...)
PS:
Sorry if something is not clear, English is not my native tongue.
