I have been able to publish information to Google Earth without problems, but when I change the Orientation of True North in the project, the results in Google still have the project north as North.
Is there something I am overlooking?
thanks
david
I did notice that if I export to a KMZ file and import the KMZ file and then import that into Google Earth, then the True North comes in correctly oriented.
david
I could reproduce the same with the KMZ file, as it did carry over the Revit True North rotation. Was this sufficient to bring the geometry back into Google Earth for your scenario?
Thank you,
This corrects the problem that I was having an publishes correctly to GE.
thanks
