- Mute
- Permalink
- Report
So I have a Construction Document Sheet Family. I have a Professional Seal Family. So the separate families aren't an issue. what I'm trying to resolve is the correct way to insert my seal into a project without just making it available for mass publications everytime my project gets distributed to all the different consultants and contractors.
In AutoCAD this was easy. I just made the seal an XREF and never sent out the seal block with my sheets. So if I printed in house on my server than the seal would be there, but if the documents were shared between consultants or with the Owner it wouldn't be distributed.
But in Revit I don't see a direct correlation to this. If I use an image than the image is in the project and goes with the project. If I use a Family, than the family is in the project. Either way the seal isn't protected from distribution, and now my professional seal (which I'm charged with protecting) is available for mass publication and easily distributed when I put out a project.
Is there any way to have a seal in a project, without it being in a project unless that family is sent with it?
