property line using the Easting and Northing values
5 REPLIES 5
2784 Views, 5 Replies
Hi, I have a question about coordinates and property lines.
How to draw the property line using the attached Northing and Easting points?
any advice would be highly appreciated
Thanks in advance.
5 REPLIES 5
There are two options to draw property lines. One is sketch mode. Use the other one.
in reply to: ToanDN
I find only the option to enter the Bearing and the distance in the property lines. But how to create the property line using Easting and Northing points (image attached above).
Thank you.
There are a ton of pages online on how to convert Easting and Northing to Bearing and Distance... Suggest Googling it.
But yes, in Revit you need Bearing and Distance, but sketching it works too.  Although your numbers are going to be outside of Revit's 20 mile mark.
in reply to: ToanDN
Interesting...
Thanks mate...
