Properties window not displaying
Message 1 of 10
I'm using Revit 2018 with the same interface I always have (Project Browser and Properties windows stacked on left side of screen). For some reason, when I opened Revit today the Properties window was blank. Occasionally, with moving or toggling the windows on/off, the window will be basically a duplicate of the Project Browser.
I've tried repair and reinstall of Revit, toggling windows on and off, restarting entire system, everything but a full uninstall (for sake of time). Does anybody have any direction on this?
Replies (9)
Message 2 of 10
It happens to me sometimes as well.  I suppose there's a rhyme and reason for it, I don't know what it is.  I usually self corrects by re-starting the software. But sometimes it takes a Repair to correct.
Message 3 of 10
I've tried both, even a reinstall, but nothing has cured it yet. It couldn't be a hardware (graphics card) issue, as I've used it with no issues plenty of times before on this system. Has a repair always fixed this issue for you?
Message 4 of 10
cbcarch
Any change a Windows update happened in the background?
Cliff B. Collins
Registered Architect The Lamar Johnson Collaborative Architects-St. Louis, MO
Message 5 of 10
It's certainly possible. What would be the course of action if this were the case?
Message 6 of 10
Fortunately, yes. I've never needed further troubleshooting beyond Repair.  If you can't Repair it, then I'd contact Autodesk.  Maybe @Viveka_CD can educate us both?
Message 7 of 10
Had to completely uninstall and reinstall Revit, repair didn't do it. I wouldn't exactly consider this a "solution" so if anybody else has a suggestion for future reference, it would be appreciated.
Message 8 of 10
We have the same issue in our drawing office on one of the Dell Workstations.
Quadro K4200 with updated drivers, No recent Windows updates.
Message 9 of 10
Not sure if this will fix your issue: RESET UI
Try resetting the UI instead of doing a repair.
Message 10 of 10
@Anonymous
I might have the resolve you are looking for.
Using the UI reset tool provided by Autodesk, I ran the .bat file, re-opend the project and the Property Window displayed fine again.
As to doing a repair, it did not work. So check out this POST to see if you agree, the RESTUI is in this link. Or attached for easy access.
Our system: Revit 2018.3 on Windows 8.1 on Dell Precision 5810
