- Mute
- Permalink
- Report
I have a new mystery happening on a small ADU project. The owner had a survey done after I had already drawn her property lines and Existing garage based off of a parcel map and rough measurements. I brought in the new survey which did align perfectly with how my true North was set up and pinned it down. However I then wanted to rotate the existing building very slightly to align with where the building is based off of this new survey. So I Selected all model elements and rotated it and everything rotated fine. But the problem is that all my views sit about a degree or two off from orthogonal. So I tried to do the rotate project north and align to that left wall but instead of it working it just says that Revit successfully processed all the elements but then doesn't actually rotate. I tried rotating project north 90° and then back. I've tried deleting all the scope boxes. This one is really stumping me. Another weird thing is that my walls and everything have disappeared from my new floor plan. But when I hover over the walls can tell they are still there and I can select them.
Has anyone encountered anything like this before?
