Project shared parameters added to revit families
yara.cp.pereira
Message 1 of 9
yara.cp.pereira
Hi all,
First time I am receiving a request to incorporate project parameters into a family. And I am not sure what is expected here and why..
So I received the bellow shared project parameters (image) to add to Revit families.
Do you know if I am supposed to add all of those as individual shared parameters to the Revit family (obs.: the list is immense, more than 100 parameters)? And what is the purpose of that?
Replies (8)
Message 2 of 9
kostask_oionei
You can see about the purpose of shared parameters here: https://help.autodesk.com/view/RVT/2022/ENU/?guid=GUID-AEBA08ED-BDF1-4E59-825A-BF9E4A871CF5.
You have to add all the parameters that you want to use in tags and in schedules. The parameters that you want to use in schedules you can also add them directly in project.
You can manage Revit parameters inside the project and families with diroots plugin paramanager
If my post help you, please give a like.
If your question was answered please mark it with ACCEPT SOLUTION. This helps others to find answers...
Kostas Kouris
Architect Engineer, M.Sc., ACI, ACP
Message 3 of 9
RDAOU
@yara.cp.pereira
Most probably not all...I would say they expect you to use the applicable one but using this shared parameters .txt file in order to maintain the same GUID.
While parameters are case sensitive, they might still end up with duplicate parameters with the same name/case if such parameters has different GUIDs (ie: you randomly recreating them from your end). Hence, they have forwarded you their .txt and expect you to use it when such shared parameters are required.
Message 4 of 9
yara.cp.pereira
Hi @RDAOU ,
I didn't know what to expect as an answer, but that makes total sense. They have previously mentioned that there was a couple of duplicated parameters in my Revit families, and I was preparing myself to delete them. Now, I will just replace them with the corresponding parameter in their file.
Superb, once again you saved my life!
Message 5 of 9
yara.cp.pereira
Yes I use diRoots, it makes life so much easier! thanks
Message 6 of 9
RDAOU
@yara.cp.pereira wrote:
Hi @RDAOU ,
@yara.cp.pereira  😮 I did?! From where I am sitting it appears that Kostask is the life guard on duty lol
Message 7 of 9
yara.cp.pereira
You both did in a way! I clicked to accept your answer as the solution, but apparently it didn't trigger. Its ok now!
Message 8 of 9
RDAOU
the thought of being a life save is more intriguing than a solution 🙂 thanks either ways
Message 9 of 9
yara.cp.pereira
Sure, I guess I want to keep my life guards motivated 😎
