Toposolid Cut / Fill Calcs
0 ANTWORTEN 0
Nachricht 1 von 1
umut.akparlar
235 Aufrufe, 0 Antworten
I want to create an irregular shaped toposolid for an existing topo surface of the construction area but when I create one it shows some cut/fill amount before modifying toposolid. It is a existing topo so I don't need any cut fill calcs before modifying the toposolid.
Is there a way to create an irregular shaped toposolid and reset cut and fill before starting to modifying points?
I can only calculate cut/fill for linear shaped flat surfaced toposolids.
Thank you for your support
Tags (1)
Beschriftungen (1)
0 ANTWORTEN 0
