Project Parameter for Slab Edge does not show in properties dialog!!???
15 REPLIES 15
Message 1 of 16
pipapongo0909
2662 Views, 15 Replies
Hi forum,
i've got 2 project parameters ( instance, Yes/No) attached to the category slab edges inside Floors, but ONLY ONE of them is showing in the properties dialog if a slab edge is selected.
Does any body has an idea why this strange behavior is happening? please see attached PDF for better understanding.
thanks in advance
Jeff Wurth
BIM Manager | Dipl Ing. Bauingenieur
LinkedIn
15 REPLIES 15
Message 2 of 16
in reply to: pipapongo0909
HI MATE,
IN PROJECT PARAMETER UNCHECK FLOOR AND CHECK SLAB WITH OTHER CATAGORY. SLAB EDGE.JPG
SEE ATTACHED REVIT FILE (VERSION 2016)
Message 3 of 16
pipapongo0909
Hi @Anonymous,
thanx for your answer.
Is that a BUG?
Actually i need the parameter on FLOORS & SLAB EDGES and several other caterories like WALLS, STR. COLUMNS,....
Any ideas?
Jeff Wurth
LinkedIn
Message 4 of 16
Sahay_R
Click to check multiple categories as shown in the previous post.
Rina Sahay
Autodesk Expert Elite
Revit Architecture Certified Professional
Message 5 of 16
pipapongo0909
in reply to: Sahay_R
Hi @Sahay_R,
thanks for your answer. I do not really understand what you mean.
@Anonymous & @Sahay_R:
Do you mean to uncheck floors and check another category. After that reselect the desired categories. ??
This will not work since the parameters are also refering to the category "floors" where the data is already filled in. If i uncheck that category, all the data will be lost.
I really do not get this
thanks in advance
Jeff Wurth
LinkedIn
Message 6 of 16
Sahay_R
It's possible to assign the same parameter to different categories. For instance, I can assign the same parameter to Casework and Furniture, if needed.
Rina Sahay
Message 7 of 16
pipapongo0909
thx @Anonymous, I thought i did that....
here more in detail
As shown in the PDF of my first post:
    the parameter: "SA_WaterproofedConcrete" is assigned to:
        floors and Slab edges
        Roofs
        Structural columns
        Structural Foundations
        Walls
    the parameter "SA_ExposedConcrete" is assigned to:
        Floors
        Structural Columns
        Structural FoundationsStructural Framing
        Walls
For both parameters the settings ( Discipline, Type, Group under,...... ) are exactely the same
And yet only "SA_WaterproofedConcrete" is available in the instance properties of the selected slab Edge...
What am i missing?
Jeff Wurth
LinkedIn
Message 8 of 16
Sahay_R
Click on Edit Type to make sure that the parameters have not been assigned as Type Parameters. If that has been the case, then you can always edit the Project Parameters to change from Instance to Type and vice versa.
Rina Sahay
Message 9 of 16
pipapongo0909
thx, but thats not the case as the snapshots on the pdf show aswell.
yet another Revit mistery.....
thx anyway
Jeff Wurth
LinkedIn
Message 10 of 16
Sahay_R
Can you share a file? Intrigued here!
Rina Sahay
Message 11 of 16
        Roofs
        Structural columns
        Walls
        Floors
        Structural Columns
        Walls
What am i missing?
Because the parameter "SA_ExposedConcrete" is not assigned to Slab Edges per what you list above?
Message 12 of 16
chrisplyler
in reply to: ToanDN
He does have Slab Edges checked for both in his photo though. Maybe he hit Cancel instead of Apply after he took the screenshot?
Message 13 of 16
Sahay_R
in reply to: chrisplyler
I just replicated what the OP is talking about. And it works for me.
Rina Sahay
Message 14 of 16
here more in detail
        Roofs
        Structural columns
        Walls
        Floors AND SLAB EDGE (r u missing this?)
        Structural Columns
        Walls
And yet only "" is available in the instance properties of the selected slab Edge...
What am i missing?
EXPAND CATEGORIES FLOORS AND UNCHECK AND CHECK SLAB EDGE for SA_ExposedConcrete then it will be shown in slab edge properties.
its works for me. (works on other categories to) if you dont expand floors then it will not visible in slab edge. hope u will find your answer.floor slabedge.JPG
Message 15 of 16
pipapongo0909
thx @Anonymous,
this did the trick!
Here is a complete step by step how i solved it! ( this definately seems me like a bug though)
starting point: all parameters are already setup to the desired categories including slab Edge but are not showing in slab edge.
  1. in project parameters dialog: select the desired parameter and hit "Modify"
  2. uncheck slab Edges and check again.
  3. before hitting OK make sure you click on the "+" before floors to unfold the tree. in other words: "Slab Edges" must be visible before you hit OK.
thanks to all for your help.
Jeff Wurth
LinkedIn
Message 16 of 16
YES THATS THE TRICK.
If it solves your problem, feel free to click Accept Solution.Smiley Very Happy
