- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
TLDR: Would someone explain the logic as to how Project Information properties are connected to model elements?
I'm curious about one aspect of how Project Information works. A friend showed me some Multi-Category schedules he had made which each included one parameter from the Project Information. For example, he made one schedule which showed "Client Name," another for "Project Status," and so on. Upon dissecting these schedules, I found that when I checked "Itemize Every Instance," there were thousands of rows, all of which showed the value of the scheduled property. See the first image below in which the scroll bar became impressively tiny after checking this option.
Mystified, I mulled this over for a bit. Then, curious, I came back and did what all seasoned Revit users casually do: select about 2,000 of these items and click "Delete." As I suspected, a Warning box popped up and showed various effects of this action, all of which pertained to deleting model elements. 'Fascinating!' I whispered, 'This Project Information property is tied to the model.'
Quite intrigued, I pressed on in my experiment. I created a new project file, created an identical schedule to my friend's showing the Client Name, then typed in a value for Client Name in the Project Info menu. Yet nothing showed. Puzzled, I opened a Floor Plan view and created two walls, then looked once more at the schedule. Still nothing showed. Which brings my question: is there a way to understand how the Project Information properties are connected to model elements? Evidently these properties are connected to some, but not all, model elements. Consequently, to make a value appear in a schedule, at least one of a selection of model components must exist in the project. But which model components?
This is all to satisfy my curiosity and not necessary for a project to move forward. Still, will anyone explain the logic to me?
The scroll bar shrunk when I checked the box
