Radial Array Not Working
7 ANTWORTEN 7
Nachricht 1 von 8
lilflor
1279 Aufrufe, 7 Antworten
Hi, I’m trying to do a radial array and am following all the steps but the component I’m trying to array keeps going outside of the path I want it to follow.  How do I fix this?  Thanks.
Beschriftungen (1)
7 ANTWORTEN 7
Nachricht 2 von 8
ennujozlagam
als Antwort auf: lilflor
share you file so we can check. thanks
Nachricht 3 von 8
lilflor
als Antwort auf: ennujozlagam
Okay I have attached the file
Nachricht 4 von 8
It happens. Use Align and Lock on the Arrayed Element.
Nachricht 5 von 8
bin
Change the category.
Nachricht 6 von 8
_Vijay
Hope this one will help you..
Nachricht 7 von 8
ennujozlagam
i agree with @bin you need to change the categories from wall to generic model then you will be able to array. thanks.
Nachricht 8 von 8
@lilflor
I wouldn't use an Array for these walls. Too much work. I would use a Curtain Wall. Be so much faster and easier. I would sketch the path with Model Lines and place these Curtain Wall via Pick Lines method.  That's how these RED Curtain Wall Panels are placed.
