Project Browser resizes randomly
j0258169
Message 1 of 33
j0258169
I have my Project Browser snapped to the right side of my main Revit window. Sometimes (frequently, almost every time I'm working in Revit) the Project Browser will suddenly shrink width-wise. I can't recreate this phenomenon, so I'm not sure exactly what is causing it.
Any ideas?
Replies (32)
Message 2 of 33
Karol_Piroska
same thing happens to me.
Message 3 of 33
Welcome to 2019 I guess. Try the latest update see if it will be fixed.
Message 4 of 33
biztrobill
Curious if anyone has found a solution to the randomly shrinking Project Browser? I use Revit LT 2020 in one window. Properties palette on the left and project browser on the right. Both docked. No problem with the Properties palette but the browser shrinks in width every few minutes. Someone suggested that I not maximize the Revit window but stretch it to fit the screen. That hasn't helped at all. I use the latest version of Revit LT.
Any suggestions would be appreciated. Thanks!
Bill Fowler NCARB
Revit LT Suite 2024
Mac M2 Pro Mini, Apple Studio Display; w/ macOS Ventura, Parallels 18, Windows 11. 32GB memory (Parallels assigns 16GB for Windows virtual machine)
Solo Architecture practice in residential and small commercial design.
Message 5 of 33
Still no answer? 🤐
Message 6 of 33
biztrobill
Dead silence...
Anybody?
Bill Fowler NCARB
Revit LT Suite 2024
Message 7 of 33
On this page (https://www.revitforum.org/showthread.php/40351-Width-of-Properties-and-Project-Browser-keeps-changi...) you can see more people suffer from this weird situation. They don't have a solution either. At least it's active 😅
Message 8 of 33
lawrenceh
Not sure if this helps but with my Windows 10 PC if I set the display settings to 100% then I do not get resizing of my Project Browser, however, if I set my laptop screen to 125% (which I do if I am using the small screen) the Project Browser shrinks in width. This normally happens when I open a new project or restart Revit.
Message 9 of 33
j0258169
Unfortunately doesn't solve it for me. My display settings are already at 100%.
Message 10 of 33
This happens to me 10 times a day. Would be super interesteed in a solution.
Message 11 of 33
Still the same problem with the newest hotfix of 2020..
Message 12 of 33
S.Childs
same issues on multiple machines.. Revit 2020.2
Why is there no fix for this?
Message 13 of 33
morehead
Same issue here, width reduces so you cannot access views efficiently - any fix?
Message 14 of 33
pkolarik
I can confirm this still happens in Revit 2021.1.1
edit:  Not only does the project browser randomly resize itself, but new to 2021 (for me) the properties windows also does so.
Message 15 of 33
scott_bolton
I found the solution on the Autodesk Knowledge site: 😣
Workaround:
Manually resize the properties palette or the project browser.
Message 16 of 33
S.Childs
Not sure that is a workaround, it doesnt stick and will go right back to jumping around. Obviously, when the project browser is changing size ramdonly/automatic just from switching from active models, we are having to MANUALLY resize back to the way it was.
Message 17 of 33
scott_bolton
Apologies. I was unable to find the English word for "sarcasm".
Message 18 of 33
S.Childs
it would be nice to get an response from Autodesk, but here we are ..
Message 19 of 33
scott_bolton
I've undocked my properties palette and project browser and placed them on another monitor and so far (a couple of hours) they don't resize.
Message 20 of 33
S.Childs
yes i do believe that it happens only when they are docked. i personally havent seen it resize them when not docked .. 🤔
