Project Browser Missing in Revit
Message 1 of 10
missing project browser.view  tab is checked and  i dont use  dual screen and i  also deleted  UIState.dat.
Replies (9)
Message 2 of 10
Viveka_CD
Hi @Anonymous
I see that you are a new visitor. Welcome to the Revit Architecture community! Smiley Happy
Which version of Revit are you using? Can you try a repair of Revit and see if this helps?
Also, check if you have the latest updates installed for your Revit version from your Autodesk Desktop App.
Message 3 of 10
cbcarch
Try:
View Tab>User Interface>Check then uncheck, then re-check Project Browser.
If this doesn't work, see if the Project Browser is "hiding" behind another window.
Cliff B. Collins
Registered Architect The Lamar Johnson Collaborative Architects-St. Louis, MO
Message 4 of 10
I cahnged the display settings from low resolution to recommended and now it is done. Thank you for your advice.
Message 5 of 10
project  broswer is missing i need your help plesse contact this mail infome
Message 6 of 10
Viveka_CD
Hi @Anonymous
Welcome to the community!
Did you try the recommendations mentioned above?
What version of Revit are you using? Can you check if you have the latest updates installed?
Message 7 of 10
How do you know the browser is hiding behind something. I can get all the browsers to show except properties and project browser which i moved yesterday after a Zoom
Message 8 of 10
cadtasticMM3TV
Observer
Observer
Hi this is Louis. I am new to Revit. I am using 2022. Every time I try to engage browser, the "modify" button jumps but I cannot get behind it. Can I reinstall Revit without losing any files?
Message 9 of 10
frederikVJN7R
Community Visitor
Community Visitor
I  have the same isue now. Properties and project browser are gone and I can't get them back on screen.
Not by going through user interface or right click on the screen. The Modify button flashes but the browsers don't show up.
What to do?
Message 10 of 10
lsherrardHZU2R
I have the same issue. All the sudden the project browser is gone and, changing resolutions, selecting it from the user interface does nothing.
