Project Browser and Properties Frozen
Message 1 of 74
My computer crashed earlier today and since i've started up Revit again my project browser and my properties have become frozen. I can maximize and minimize them but i cant move them anywhere or click on anything thats in them.
I've rebooted and also run a repair but no luck.
I've searched countless forums and cant seem to find anything relating to the problem and revit is unworkable without these 2 items working.
I'm running Design Suite 2014.
Any help is appriciated.
Accepted solutions (3)
Replies (73)
Message 21 of 74
I tried this, and my Project browser & properties window were still frozen after re-opening revit. I did notice my tower and monitor were slightly moved when i came into work. Turns out the IT guy added a 2TB hard-drive over night. Somewheres i read it being related to the User profile. So i went in Revit options and changed my name to Admin, and opened my local copy. It gave me the prompt to change my name back after, and when i did...BAM! My properties window and project browser were free..
Not sure exactly what fixed it, but i was able to avoid calling IT doing these steps...so thanks for the Help!
-Elliott
Message 22 of 74
frngomez
Community Visitor
Community Visitor
Worked for me. THANKS!
Message 23 of 74
Sachin.Kathare
It works!!
Message 24 of 74
Yes, I had to reboot my machine. Apparently my Revit session was cut short by windows updates while I was at lunch.
Message 25 of 74
this works
Message 26 of 74
It worked for me!
After reading posts suggesting a repair to REVIT and updating my video card driver, I did both - to no avail, then I merely logged in as ADMIN and my browser and properties manager were unfrozen.
I still would like to know what caused this problem. When I finished with my project one day, I saved it, and just let my computer go to sleep, like i do much of the time. Then, when I woke my computer up the next morning to work on the project again, the browser and property managers were frozen..
Trimetal
Message 27 of 74
I was so freaked out because I am in the middle of a project that needs to get done today. Your solution totally worked!!!
Message 28 of 74
No Problemo,
I did not invent it, or discovered it, just refined the instructions...
good luck
*Thanks,*
*Steven A. & Hilma Timper*
*Your Real Property Consultant - Home Team Realty*
*California Contractors License #957530*
*Autocad Plan Design/Blueprint Production for your permits (if you need
them)*
*Certified International Property Specialist Candidate CIPS/NAR*
*Shortsale and Foreclosure Resource (SFR) Designation NAR*
*Selling your properties to Buyers for over 15 years*
*EPA Certified Lead Based Paint Renovator*
*CA Real Property Appraiser*
*Director – Greater Southbay Regional MLS - 2006Director – California Assc.
Realtors - 2006Chairman – Southbay Assc. Of Realtors MLS Committee –
2005/2006Instructor - Matrix Instructor SBAOR*310-993-7957
310-993-7957>* Cell Steve*
310-462-6155 310-462-6155>* Cell Hilma – Hilma is fluent in
Spanish, and a RE Agent*
310-601-1823 310-601-1823>* Fax*
*DRE License #01147226*310-601-1823>310-462-6155>310-993-7957>
Message 29 of 74
arrowrah
Another solution that has worked for me. Open any file and go to the View menu > User interface > Browser Organization > Select a different settings under views. This should restore the functionality of your Project Browser and Properties palette. Now you can change back to the original view in Browser Organization.
Message 30 of 74
Thanks  a lot, it helps me to, with Revit 2016.
Message 31 of 74
@Anonymous wrote:
I have just gone through this issue on 2015.
I tried the 'successful' link and did not get the intended outcome. not sure if the same process for 2015 applys.
The method I used to unfreeze my project browser were as follows:
1. Open 'User Interface' under View tab.'
2. go down to 'Browser Organisation'. This is where I changed a preference. Under the Sheet tab I changed the preference to 'Prefix' ( i'm sure any tick box would event in the same outcome). Apply and OK.
This updated in my project browser which had also unfrozen my project browser . I then went through the same process to change my preferences back.
All working again!
This was the solution for me!
Thanks alot
Message 32 of 74
This just happened on one of our Revit 2017.1 systems.  Turning the hardware acceleration off and then closing and reopening the file did the trick and then turning it back on and closing and reopening the file again kept it working.  So it seems this bug is perhaps back or just never really went away?
Message 33 of 74
Very helpful, thank you!
Message 34 of 74
Hi there,
Another quick option is to go to the options tab and temporarily edit your username - not sure the reason this works but is fairly option to try.
Message 35 of 74
kristina.williams.22
DMartin - My workaround posted above was to simply open the Options dialog and close it, which unfreezes the other dialog boxes.  I think this is why your suggestion works, because in the process, the Options dialog is opened and closed.   You might try skipping that extra step of editing the username to save time.  Hope that works for you too!  Every step counts...
Message 36 of 74
jkidder
We just had the issue for a user on 2017.1.1 - Frozen properties pallet even after a computer restart and checking/unchecking visibility of boxes.  Opening a new project worked to re-enable access to the pallet.
Message 37 of 74
Sahay_R
Revit 2016 - per one of the prior suggestions - I opened and closed the Options dialog box. BINGO!!!!!
Rina Sahay
Autodesk Expert Elite
Revit Architecture Certified Professional
Message 38 of 74
Regedit did nor work for me, but selecting a different project browser setting did. Thanks
Message 39 of 74
You are a star....worked like Magic. Thank u thank u
Message 40 of 74
paulight
Observer
Observer
This works on Revit 2017 -thank you!  Am productive again!
